- Aug 21, 2009
- 192
- CircuPool Edge-40
I purchased an auroroa 24' round pool and replacing the one I have, it should be here next week, pool is scheduled to be installed on Nov. 11, digging it down 27 inches. I am relocating pump and filter tp behind my shed so am running new wiring for that (run through pipe underground). I bought a new 2 speed Hayward Matrix pump (I see that many on here use that one) and it is a 110V model. I also bought an RJ-45 SWCG and that is set up from the factory as 240V, but can be modified to 110V. My questions are: Should I run Wiring for 240 to the SWG? or run wiring for 110V and then modify the RJ-45 (have to remove a jumper or something) to work on 110V? If I go all 110, should I put the SWCG and the pump on separate breakers? 20 Amp breakers? The pump has a 6 foot pigtail on it already, so I was just going to run the wiring to my shed and mount a GFI outlet (could plug other stuff in then also if I wanted) and plug it in. I assumed (yes, I know what assume means ) that the RJ-45 would just plug in to a 110V outlet also, but was wrong about that. its a hard wired unit and 240 from the factory, but adjustable to 110V. Any advice on this would be appreciated, as I would like to try and get all this done and ready before the install on the 11th of Nov.
