Long story short but 3rd time we have had lightning take pool equipment out.
We found all of the breakers tripped and Omnilogic screen wouldnt power up did the troubleshooting and points out that the main circuit board is bad. I was trying to get my pump running without automation (we have never done that) But the pump readout says loss communications which ok that was obvious. Also says low voltage check wires between drive and display. Using the troubleshooting that i read for that pump said if you show low voltage but you have 240 volts present. Replace the drive. Any advice on this? Theres no way the automation being out can cause any of this is there? or could it be programming of the pump? I didnt want to order a new drive just to figure out the one i have is good. My 2ndary pump which is used for waterfall, bubblers etc. looks like it only comes on through automation and there is no way i can turn it on manually to even cycle water for now.
