I have a hybrid pool with a lot of osmotic blisters. No leaks yet. Bottom is in pretty good shape. At some point it has been plastered and repainted as I can see light green beneath a layer of what I guess is plaster in one or two small places and on the concrete steps which I have successfully repaired and painted.
It seems that there are two solutions for the wall both of which require grinding out the blisters, filling and sanding after which I have had two recommendations and quotes: Epoxy coating of the panels or Ecofinish.
I should add that at 71 I don't need a pool that will last 20 years because I likely won't LOL
So three questions here:
1. Any preference as to method?
If I epoxy, should I epoxy fill over the rubber seals between panels
2. Can I just use Ecofinish on the walls? The bottom is in great shape so it seems a share to sandblast and Ecofinish and I do like the blue wall white bottom but that is minor compared to the cost based on square footage.
One of the two local Ecofinish guys clearly did not know the type of pool as he thought that there was a silicone seal between the wall and bottom and the Ecofinish torch would cause a leak. The other wants to do the whole pool as he has done it before.
Thanks in advance. Great website
While I had pools in previous houses this type is new to me
