I have a Sylvan pool that was originally gunite.
About 17 years ago I purchased and installed a fiberglass kit to resurface. The kit contained 4ft wide strips of fiberglass which were glued onto the surface and then (I believe) a gel coat was applied as a final surface.
The product has held up well however now is showing signs of needing resurfacing. The company that I bought the kit from, UGlassit ?, is no longer listed so I'm unsure of the final coat.
As I suspect the surface is a gel coat, can EcoFinish be applied over that?
What kind of cost am I looking at for a EcoFinish pool approximately 39x24 - 4800sq ft?
