- Aug 28, 2024
- 5
- Plaster
- Pentair Intellichlor IC-40
Hello, I am having an issue with my Easytouch 400 not controlling the temperature of my heater. This happened all of a sudden when I was using the spa I noticed that the temperature just kept rising so I went out to take a look at the heater saw that it was set to 104 on the heater and that the heater was only responding to using the manual controls on the heater itself. Heater is working fine manually. When I set a temperature in my phone for the heater to go up to or if I set a temperature below the set point the heater does not respond at all it will not shut off until it reaches what is set manually on the heater control panel. The temperature settings I set on my phone show on the Easytouch screen but the heater does not respond to those. I looked at the Easytouch 400 it does have a two wire connection on the circuit board which has a number on it J19/heater. The two wires(looks like a single wire but is two wires under the insulation) are going from that connection to the heater. Not sure what to do next. Thanks!
