Easytouch 8 with TWO 2-Speed Pumps?
Sep 23, 2018
12
Fulshear, TX
Is there a way to run two 2-speed pumps with an Easytouch 8?
I have one 2-speed Whisperflo pump running my filter/heater/cleaner, using the Pentair 2-speed relay.
I have a single speed 1.5HP Superflo that runs my sheer descent water feature and my pool chiller.
I need less flow to run the pool chiller but I still want to have the versitility to run the sheer descent at full rate.
Any ideas?
Jeff,
I would think not... You could have two, 2-speed relays, but there is only one 2-speed relay port. There is some internal programming for how the 2-speed relay port works and it is doubtful that you would want both of your 2-speed relays doing the same exact thing at the same time.
I would configure one relay as the "official" 2-speed relay and configure the other 2-speed relay to manually turn on and off using two Aux circuits..
Actually, I would have used a VSP for the pool, and then the 2-speed for the water features. :p
Keep in mind that a lot of people get very tired of the constant noise from water features and end up not using them near as often as initially planned.
Yeah, that’s where I landed too. I have space in the box for another 2 speed relay but no available special purpose relay outputs (unless the solar port an be used somehow).
Do you have a wiring diagram of what that would look like with two aux circuits? Even a crude drawing?
I thought about the VSP but I’ve seen so much about the electronics frying.
I don’t really run the water feature much as it is, for the reason you cited, but I still want the option.
Thanks for the advice!
Jeff,
I am good at "crude", so let me see what I can do... In the mean time..
As an example... use the normal Aux 6 relay to provide power to the 2-speed relay plugged into Aux 7 port on the main board . Turning Aux 6 on would turn on the pump at low speed and then turning on Aux 7 would switch the 2-speed relay to high speed. You need two relays because you need one that turns everything on/off, and you need the other to switch between low speed and high speed.
Jeff,
I re-read you post.. Are all 7 of your aux relays already used???
Are you planning to replace the single speed pump or just the motor?
Just the motor.
I think I understand how to wire with two power relays vs. the 2-speed relay...except for the common wire. Where does it connect in the panel? Either one of the power relays or both?
