Here's a super simple diy funnel system for measuring out stabilizer and neatly pouring the powder into a knee high. It will take more time to read the directions than to actually make the two part funnel.
If you can imagine a red solo cup with the bottom cut out stacked on top of another red solo cup (with bottom intact) with a pantyhose sandwiched in between both cups - you can skip the instructions!
Cut a hole out of the bottom of one of the cups. This bottomless cup will be stacked on top of the other cup.
Place a paper towel on the scale and add the cup with bottom on top of the paper towel.
Position the knee high into the cup (with bottom) on the scale, then stack the bottomless cup on top of the other cup.
The knee high should now be sandwiched between both both cups.
Tare out the scale.
Now pour in desired amount of stabilizer. (You can raise the bottomless cup to accommodate larger quantities.)
Remove bottomless cup, leaving the pantyhose filled with stabilizer in the cup with the bottom. Tie a knot on the pantyhose and use the cup to carry measured stabilizer poolside.
I labeled each cup with masking tape that says, "FOR POOL CHEMICALS" on opposite sides of each cup and stored them in a ziplock bag.
Hope this makes adding stabilizer to your pool easier and less of a mess.
Please share any good tips you know that make adding chemicals and maintaining the pool easier.
