When muriatic acid is unavailable, sulfuric acid or sodium bisulfate can be used to reduce pH and lower alkalinity in a pool. But beware of sulfates! Muriatic Acid Alternatives
blog.orendatech.com
I used to buy dry acid but then changed to Muriatic acid 4 good.
And always dilute muriatic acid in a bucket before pouring to the pool.
There are some pictures showing how pool plaster gets attacked when pouring directly at arms length (leaving discoloration exactly at arms length!)
You are handling it twice. Increases risk to spill it. Simply pour at a slow rate at the return into the pool with the pump running. If you wish, brush the area afterwards.
It’s not that it harms the MA, it’s just that the more you handle the more chance you have of inadvertently splashing on you, breathing the fumes, etc.
