Over time the front drive wheel and bearing has developed a lot of slop and needs replacement. Marina seems to be out of wheel kits at present that include this little plastic part that does not seem to have a number. The bearings press-fit on the front wheel shafts. My S200 won't crawl because of gear slop on the front drive wheel.
I am going to try swapping sides with the other side's idler front wheel to see if I can get moving again in the short term
So what I probably need is a
Anyone know a source I might check besides Marina or maybe part numbers? Maybe it is a supply chain issue.
I have to say that this S200 is wonderfully easy to work on and seems to be a great design.
Thanks.
- couple of 9993219 front wheel kits that include new wheels and bearings,
- plus a new set of the nylon drive gears that run inside this wheel, one off the motor and one on the front roller.
Thanks.
