Hi - we had a water well drilled about a year and a half ago for a home we are building. The pool is almost complete, and depending on weather, may get plastered and filled at the end of the week. We are planning on using the well water for the fill.
My test kit is scheduled to be delivered Wednesday and I will test the well water for practice and to know what I am working with before the pool people add any chemicals.
Could you tell me if there is a correlation between the results of the drinking water test and what I will be testing for in regards to the pool? For example, the drinking water test showed a pH of 6.55 (low, I know). I would guess that should be a direct correlation to the pH test for pools.
Do the calcium results, 71 ppm, the hardness results, 195 ppm CaCO3, or the Chloride, 15 ppm, correlate at all to the CH test?
The alkalinity result was also listed as 198 ppm CaCO3.
The total dissolved salts (TDS) was 364 ppm.
The metals tested (iron, copper, and manganese) all showed <.01 ppm. There was a zinc reading of 1.09 ppm.
Thank you.
Thank you.
