7,400 gallon ag non slatwater vinyl
Latest numbers:
FC 6-10 daily maintenance
CYA 60 (sadly over shot cyanuric acid this spring but dealing with it)
CC .5-1
PH 7.3 (when fc is below 6; shows higher ph. Assuming the lower fc is the more accurate reading)
TA 50 (have kept it at 50 three years with few needed PH adjustments; higher levels require constant acid additions)
Going to start mustard SLAM soon. Mustard is supposed to be easy to remove from surfaces but I'm struggling to get a very faint yellowing off the floor. Bought a new brush.
Going to remove ladder and soak and scrub bleach. Open the filter and clean surface inside and check sand. Wash swimsuits in color safe bleach and soak floats.
Since I already pass all three tests, how long should I SLAM?
Any more suggestions?
Latest numbers:
CC .5-1
