draining with deep end inlet plugged
goldlinx
5
I am attempting to open my pool for the first time and having trouble getting the rubber plug out of the deep end inlet. I have all other plugs out and the water level is below the skimmers.
I want to drain the pool enough so I can drill into the rubber plug. Can I drain the pool with the waste setting by closing off the skimmer lines and open the drain line (on the bottom of pool) or would that be a problem while the inlet is still plugged? I turned it on to drain but nothing happened and was wondering if that's because the inlet is plugged.
Welcome to the forum.
If the main drain is plugged, you cannot get water through it.
I suggest you get a sump pump and use that to drain the water you need to.
