Last night at sunset I tested and calculated how much chlorine to add to SLAM. I applied the correct amount and then tested 30 minutes later. FC was 11.4 and CC .2 ...kept the pump running for 24 hours now. This morning FC 9 and CC .44 .....it's still cloudy. I'm getting annoyed. How am I supposed to SLAM during the day with a CYA 0? I was told not to add CYA at all of I'm using up some trichlor.
I won't weigh in about the chemistry, to keep this cook out of that kitchen, so to speak. I just want to help you with the OCLT. The purpose of testing in the evening and then again in the morning, the OCLT, was to determine IF you had algae, and so IF you needed to SLAM. But it sounds like you started your SLAM straight away. That's OK, you just skipped a step (the OCLT). So forget about OCLT for now, and testing for that, and refer to the SLAM directions to complete the SLAM, including the FC testing frequency (how you test for a SLAM, and how often, is different for testing for an OCLT). You do perform an OCLT, to determine when you're done SLAMing, but that will be in the future, not right now. Keep SLAMing, and following the SLAM directions, until you can pass the three "end of SLAM" criteria. You'll find those in the SLAM directions.
I know this can be frustrating, but you'll get there. If I may: read directions carefully, and follow them exactly, don't cheat (or you'll just have to start your SLAM over again). Same goes for posts, especially posts from our TFP Experts. I'm not a TFP Expert, but Marty is (
@mknauss). Focus on his instructions, and answer his questions promptly. I think you'll find that will help eliminate some of the confusion and hopefully get all this behind you as soon as possible. Chin up!
If it helps, you have smooth sailing to look forward to. This is the worst of it. Remember, you're still cleaning up someone else's mess. Once you get your pool in "TFP shape," you'll find you only have a bare minimum of things to do, and things to buy. It really will get easier, a whole lot easier...
