I know there are a lot of us throwing a lot of things at you. Me as bad as anyone. Aren't we helpful!!
Work with Marty on the SLAM. He's advised you to remove the pucks from the pool. Do that. You mentioned earlier that you had the pucks in a floater. I believe that is the preferred method. But just now you wrote you have them in the filter. Did you mean you have them in the skimmer? I've never used pucks in my pool, but I'm pretty sure I read here that having them in the skimmer is bad. They are acidic, and as they dissolve, all that acid is not good for the skimmer or the pipes. Take them out for now, and if you use them again in the future, don't put them in the skimmer, use a floater. Others here will correct me if I'm remembering that wrong...
