Hello Trouble Free Pool, long time lurker, first time poster. Are you ready for a horror story? I'll try to keep it brief, really. With warm weather leaving us and cold days ahead, I've got a question.
I bought a house with a pool, closed October 2021. Just repairing the hidden damage to house itself has been the primary focus for almost a year (it's been a nightmare of course, I could go on). The pool itself is a hybrid pool, built in 1985. It has a painted concrete bottom with what seems to be soft vinyl sides (I can't tell for sure), and a fiberglass lip above the waterline. Amazingly, the equipment is in (nearly) perfect working order even though it seems to be original. I've had no issue running the pump 24/7 and the sand filter does its job.
The problem is the pool itself. The paint is dissolving*, the caulk along every seam is disintegrating and peeling away, and it's losing water faster than what evaporation could explain. It loses about an inch a day. The pool's size is listed in my profile.
So here's the thing: I'm happy to take my time and DIY repair these things when the weather turns nice next spring/summer, and I'll just winterize it until then. Either I'll repair and repaint the pool, or install a liner. Either way though, how do I keep the walls from collapsing when I drain the pool? It's not going to pop out of the ground like a fiberglass pool might, so I assume some kind of frame is the solution? Would lumber work? I couldn't quite find a TFP post about framing hybrid pools in order to completely drain them, but please let me know if someone's already done this and detailed how.
Or, is this a non-issue? The pool is about 4.5 feet deep at its deepest. I don't want to take any risks, but if the walls simply aren't tall enough to collapse, then maybe it's fine to completely drain it with no frame?
Finding a contractor to do it for me is the last thing I want to do after all the expenses refurbing this house has cost me already, and especially given the fact that hybrid pools are
*About the paint, I thought it was dead algae settling during SLAM, but after the water became crystal clear and all the chemicals had been balanced for weeks, passing the SLAM requirements multiple days in a row, the brush would still kick up white clouds. I scraped the bottom of the pool with some plastic to confirm, yep, the paint was coming off.
I can get photos, just let me know!
