Hi. 2 inch por day is a lot of water. I make the same to find leaks before I make a pressure test. In the most case the problem is the pool lamp. If you cannot find, close all poolvalves and wait until the water stops. If you think the floor drain is the problem, try to put a plug in. Its 1,5 inch or 2 inch.
