My above ground pool has been uncovered and unused for two years. I hired someone to drain the pool and clean it. I refilled the pool only to discover the pump wasn't working. So the pool has sat full with no chemicals and no pump running for over 7 days. The pump has been repaired and runs fine but now I see signs of green around the outer edges on the bottom of the pool. Do I test anything now or just start adding the normal chemicals and then test? Do I SLAM the pool? I would assume so since I see signs of algae. There is currently no CYA so would I need to add that initially and let it stabalize before adding/testing anything else?
24" ABG
1.5 Hayward Power-Flo Matrix
Sand Filter
Total Poolcare DPD Test Kit from Leslie's
24" ABG
Sand Filter
