Good afternoon,
I recently tested my water and was told that the CYA ppm was 161 (normal range 30-100) and was told to drain it, so I did yesterday and just finished filling it up a few hours ago. Info on pool: I have an in ground plaster, medium gray color which holds approx. 15,000 gallons located in Southern CA. I called my local pool supply to ask what chemicals do I need to add for starters? They told me to add 2 gallons of chlorine and one gallon of muriatic acid which I have already done. Also, what water test kit would this forum recommend, one that includes a test for CYA ppm. I read a blog in which a test kit made by Taylor “Complete (FAS-DPD chlorine) M/N K-2006 was recommended
Please advise,
Please advise,
