- May 8, 2020
- 482
- Plaster
- Pentair Intellichlor IC-40
TA of 120 isn't really all that bad. My post was intended for those that have TA north of 150. My guess is that if you just manage pH as you indicated, and run the waterfall, you will be just fine...I found a while ago that the aeration wasn't really necessary because a daily run of the SWG over the waterfall and spa spill would push pH up naturally but for startup I'll do it.
The error tolerance is like +\-0.3ppm so maybe it’s 0.2 or 0.8 or anywhere inbetween.Got a test of hose water for Cu. It's 0.5ppm or maybe less.
It was a test strip? Don’t worry about it in that case.It was in between colors on the test strip so IDK?
^^^^^ I fixed it for ya.It was a test strip so IDK. I might as have well tasted the water and guessed.
The pressure washer was a bit useless on removing it anyhow..It has to be used very carefully. A pressure washer can damage plaster.
Well I had one too based upon the scope of the work accomplished in a very short time. I'd be waiting for callbacks for at least another 2 weeks. *Then* I'd have to wait my turn after deciding who to use.Why the shocked look @PoolStored ?
This young man is prompt and works hard. He polished it for a solid two days at a solid 8 hours a day and will be back this morning to finish up.Well I had one too based upon the scope of the work accomplished in a very short time. I'd be waiting for callbacks for at least another 2 weeks. *Then* I'd have to wait my turn after deciding who to use.
(Though you did say you had a regular guy).
Also, absolutely LOVE the supervisors doing their thing. Maybe you could get them mini clipboards.
