Drain Water From Pool - Cartridge Filter
rwright88
2
Wake Forest, NC
Hello all,
First post, so go easy on me. I wanted to see if anyone knows of a kit or fittings that would allow me to hook up a backflow hose (or something like it to help me route the water away from the filter? I know there is no backwash function, but need to drain the pool a bit and trying not to get a pool of water in our equipment shed.
Thank you in advance.
Rick
Filter is a Pentair CC200
DoubleEcho
124
Pennsylvania
Do you have somewhere you can drain the water legally and safely? You could install a PVC ball valve and a tee and route plumbing somewhere else. I live in the country and can drain it into my yard so that solution works for me.
Rancho Cost-a-Lotta
1,816
Rancho Cucamonga, CA
My pool has a hose bib plumbed after the filter like the one in the post below. If you need to drain below the skimmer, you'll want to use a submersible pump as @Razorhog suggested.
markayash
2,890
Atlanta Ga
Do you have a pressure side pool cleaner? Thats what I used for a few years, just took the hose loose from the polaris
