I don’t know who all watches tiktok but any thoughts on this? Looks interesting LOL ^
Yeah, my thoughts are this guy doesn’t know what he is talking about. First, sand doesn’t need to be changed, although it might need a deep cleaning. The cartridges needed to be hosed off. And that blue mineral stuff is copper-based which will lead to staining and should not be added to a pool.
I can assure you that my pool is crystal clear without anything like that. Chlorine form the salt water generator, stabilizer, and acid to reduce the Ph every once in awhile. Less is better.
Is sand expensive? I agree with cleaning the cartridges, but sand? Does a sand filter require some sort of special/expensive sand?$109.00 for a single treatment. Plus this guy would have folks throw out perfectly good cartridges and sand instead of cleaning them.
Sure, try it and see if it helps.What about sticking your vacuum hose down at that end so you pull the water from the bottom?
