Did you add CYA? There wouldn't be any CYA in a fresh fill, it's something you add to your pool.
Yep, sure did, about 5 pounds of dry CYA from a sock. Spent a lot of time brushing to mix in the bits that escaped.
Are you planning to take care of the water yourself? Have you read Pool School, and learned about Pool Math?
Yep, been reading as much as I can for the past few months and going to try to take it on myself.
Was able to get the FC up to 6.5 and pH up slightly, and the CH up to 250 later on in the day as well. TA came down to 110. So I think pretty much everything is where it should be at this point.
Thanks for all the help!
