I bought this little pump to add liquid chlorine to my hot tub during times when I will be away from our house on vacation.
We just bought a used fifth-wheel and will be taking trips of anywhere between one week and six weeks. So I wanted a simple solution to keep the water clear while we are gone without having to bother a friend to stop by and add chlorine. We have storage steps in front of the spa. I will locate the pump and chlorine jug inside the storage steps. The pump will run on a timer. I tested the pump/timer set-up yesterday and it moved 2.7 ounces of fluid via slow drip in one hour of run time.
I am trying to determine a good level of chlorine to add daily while we are away to keep the chlorine levels adequate to maintain clear water. Obviously, I want to err on the side of too much vs. too little.
We use the hot tub daily -- just me in the morning for 15-20 minutes then usually my wife and I in the evening for 15-20 minutes. I add about 2 ounces after my morning soak and about 3 ounces after the evening soak. This has worked great for years.
I am just not sure how much lower the chlorine demand goes when a tub is not in use. I was thinking I could run the pump for 30 minutes per day when we are away, which would put in about 1.35 ounces of chlorine per day. Does that sound about right or should I bump it up a bit just to be safe?
BRS 2 Part Doser - 1.1 mL per minute
Why does BRS recommend this? The BRS 1.1 mL dosing pump is a very cost-effective yet long lasting stand-alone dosing pump perfect for trace elements and 2 part. By hooking the pump up to a simple timer or aquarium controller they can be one of the most inexpensive ways to get into an automated...
www.bulkreefsupply.com
