Dolphin Cleaner During SLAM
What I would do is use the Dolphin for its superior cleaning ability, but remove it from the pool after its 2 hour cycle. Clean the cartridge filters thoroughly and leave it out until you are ready to use it again.
Reactions: KristaM78
This is somewhat related I suppose, but is it ok to leave the robotic pool cleaner in the pool while treating it (not just during SLAM but if I'm just adding stabilizer or Acid, etc.)?
I'm probably not the right person to ask because I pull my robot out of the pool whenever it's not running. Just the way I am. I am sure, however, if your pump is running while dosing as it should be anyways that your bot will be fine.
Reactions: ScottyJ2
