I've been having issues with my cleaner not finishing the cleaning cycle and it's now progressed to where it won't get past the self-test. I took it apart, cleaned the impeller (not much there) but still the same issue. I tried reengaging the motor (removing it and placing it back in) - still nothing.
Next I ran voltage tests. Everything checked out find until I got to the blue swivel cable. I could not get a reading at the end that plugs into the motor. I did a continuity test, but I'm not sure if what the results mean because I've never done one before. I was only able to get a continuity beep from one of the two prongs. Does that mean that the cable is bad? I'd like to be sure it's bad before I replace it.
