After I add the R-0871, and the water becomes clear, I have noticed that - if the water is left in the vile - after a minute or two the water will once again return to pink. Is that normal? Or does that mean that I am doing something wrong?
I’m using the TFP test kit and the Taylor speedstir.
I found this, so I think I’m good?
“...the pink color slowly comes back over time even when you add nothing. This is why Taylor explicitly says that the ENTIRE test (FC and CC) needs to be completed in under 1 minute from the time you add the powder to the water to the time you finish counting the last drop for the CC test. Even taking time to write down numbers between tests could cause errors.”
Water Testing Errors - Further Reading
www.troublefreepool.com
