New circupool RJ60+ installed a few months ago. I got sloppy and let my PH get too high, so now I already have what looks like calcium scale. It seems like the swg is outputting less chlorine than it was when new, but it's hard to tell because we've had an extremely rainy summer. On the 4th straight day of rain right now.
So a couple of questions:
1. As you can see there are some thick deposits between the cell fins, some short with a couple of lengthier deposits. I've seen other "cleaning" pics where there were actually big hunks of deposits protruding off the fins, so I'm not sure if what I have warrants a cleaning yet or if it would be better not to reduce the cell life by dipping it in MA and just wait until there is more buildup. If what I already have is enough to reduce chlorine production, that would seem to pose a tradeoff since running the cell longer to make up for that is also going to reduce its life.
2. How do I dispose of the acid when I'm done with it? At first glance it would seem like dumping it into the pool to combat the ever-rising PH would be the obvious choice, but if my calcium hardness is too high, I wouldn't want to put the dissolved calcium back in unless the amount is so trivial that it won't matter. I have a septic system so I can't dilute/neutralize and pour it down the drain. There are some big areas in the backyard landscaped with pebbles and I'm not sure if it's ok to dilute and pour there, but otherwise I don't have a good place to put it besides into the pool.
