- Apr 22, 2019
- 424
- Vinyl
- CircuPool Core-55
I am replacing my liner soon. It's probably going to be some time in June, as all the companies are really backed up with covid delays, but we signed and put our deposit down today.
In the meantime I am trying to come up with a plan to avoid the issue I've been having since I inherited the pool, which is metal. This will probably be the only chance in a long time I get to do a water change.
I estimate that the pool is 20+ years old, and I have no idea how old the water itself is, but probably at least 10-14yrs. When I bought the house the pool was a swamp full of leaves and it took a long time but we cleaned it and got the water crystal clear.
BUT, it was always green-teal colored. The water itself never seems discolored, but the walls and fittings become pale yellowish (strangely, the steps don't really discolor ever). I did a few AA treatments and they do 100% clear up the coloring and the pool will be almost blindingly blue - so I know what it COULD look like!
The very first time I slammed the pool, it went this color...
The liner stained to a rusty, DARK, DARK orange...you can just barely see it if you zoom in to the waterline area. It never actually did THAT BAD again.
Eventually I started skipping AA and using high doses of Metal Magic which worked just as well but things were getting to a point where I'd need a whole bottle every 1.5weeks or sooner and it was just too expensive.
So it' usually hanging out around this color, which doesn't bother me much when it's sunny out. When it's cloudy it looks worse...
and again, the water itself seems clear... it's the walls that are light yellow.
I feel like there has been some dilution happening over the years because if you compare this photo to the ones above, it looks a lot better (besides the AA treatment photo). I have to add a lot of water to my pool with the hose, with high evaporation happening here and also I suspect this old liner has a few leaks. I am adding water every couple of days (big reason for liner replacement!)
I brought water from my pool/tap and hose to the store with me today where we are having the liner done however they were out of the metal test "disc" for the computers and no vendors have any in stock that they can get, so I was unable to do any sort of computerized testing. I do have my own copper/iron test strips however they have always read 0 which obviously isn't the case. One or the other is there...
I know that the pool was maintained in the past at some point by a local pool company because when I moved in the neighbors told me they had a pool guy come weekly. So I except that they probably had algaecides dumped in the pool a lot (copper?). I actually wish that was the issue because it seems more simple to get rid of then iron. I know things like lawn fertilizer can contain iron so that was a thought at one point. They also had a pool ladder in that had rust on the screws and left a rust-run mark on the liner (disappeared now).
Okay, so since I could not get my water tested I came home and filled up a white bucket from the hose and a small white bowl from the inside tap and dumped bleach in them. It immediately tinted light green however I notice the bleach coming out of the bottle was very yellow, and I am now unsure if the yellow bleach caused the discoloration or a metals reaction. My husband says it's the bleach being yellow (it was very yellow.) It's been about an hour now and the water in the bucket is still green, however, it hasn't left a stain on the edges like it does in the pool.
What was even my purpose of this thread? I feel like I am totally rambling at this point.
#1. Basically, if there is iron in my fill water, how come it appears that over the years dilution has been happening of the amount of iron that is in my pool on it's own (backwashing/splash out/ over 3 years, replacing very often with the same hose water).
#2. Is that discoloration in the buckets metal or the very yellow bleach (of which I added a lot of)
#3. Ideas going forward that do not involve trucking in water (unavailable in this city as far as I can gather), or very expensive filtration systems
Also, I am on city water.
