I’m one of those that really like my IFCS. I will never build another pool..but if I did, I’m not sure that I would get another...mostly because of the cost. IF I was going to get a new pool with an IFCS, I would make sure that it includes:
0) a powerful VSP...you need to tune your IFCS, the only easy way to do that is to adjust the RPM of the VSP, otherwise you will be throwing away money running a pump at high speed all the time...something everyone on this boards seems to dislike, including myself. Compared to the cost of a new pool, power usage for many is a secondary issue.
1) full automation including the ability to pull suction 100% from the drain when using the IFCS popups...must also include the ability to run with 100% suction through the skimmers and back through the wall returns (for low speed skimming and chlorine generation). You need to run your VSP at high speed for 2-3 hours for popup operation (inefficient), and then at low speed (not through the popups) for much longer times (almost free with a VSP).
2) a channel main drain to collect the debris pushed around by the IFCS
3) a leaf basket if you have trees or other debris shedders anywhere close...the pump basket is too small
4) a smaller pool...IFCSs are not for big pools...yours qualifies but I don’t know about the rectangular shape because small debris will probably collect in the corners.
5) I don’t have a spa so do not know about that...is the booster pump for that or the sheers/bubblers, not for the IFCS?
6) minimum 2” pipe returns to the IFCS popups, with a 2” IFCS manifold. The # of heads on each zone has changed dramatically over the the years...I think they are trying to get by with more heads on each zone which can be problematic...but I don’t think you will have much choice on that, the pool builders contract the design out to the IFCS manufacturers...make sure they follow the plan exactly.
7) Last summer I “discovered” the ability to swirl my pool with the wall returns to enhance skimming action. Thanks Rob! Don’t know if you will have that ability with a longer, narrower pool. It’s made a big difference: material is collected from the surface with the “cheap” skimming before it makes its way down to the “expensive” popups. Haha.
The pcc2000 is the only IFCS system I know of that claims to “direct” the debris towards the drain...it could work with your pool slope towards only one end...but I am still personally skeptical. My system, and most IFCSs, randomly push stuff around until its sucked down the drain. All that being said...I run my system for about $10/month so I’m happy with it. I haven’t brushed or vacuumed my pool since the final of last summer’s monsoon...I know, I’m lazy, but I have scooped out some floating debris a few times after some high winds.
Good luck with your decision.
