Hey folks,
So I, like an idiot, put phosphate remover in my pool because my phosphates were incredibly high (3000+ ppb).
This clouded the water, as expected, and I cleaned my filter cartridges everyday for the last couple of days.
I noticed today that my filter pressure was still +10 psi higher than it should be, even after cleaning. After removing the cartridges and running the pump on its own the PSI went back down to the normal level it should be...meaning that my cartridges are clogged AF with lanthanum phosphate.
The filters are basically brand new (installed them 5 months ago). They still look like they just came out of the box, but when I look into the pleats I can see that there is a ton of lanthanum phosphate right in the inner most part of the pleats that my hose cannot seem to wash out.
I am soaking them in 1:20 muriatic acid for 2 hours to see if this clears the issue, but it got me wondering:
Is the 1:20 muriatic acid treatment going to help out?
Is there some other chemical that will dissolve these stuff that is safe to use?
Perhaps a different procedure that I can do to remove this stuff?
Or are my cartridges just ruined and I need to get new ones?
