FYI, pH is not measured in PPM.
The pH test has distinct coloring if you ignore all the numbers and just look at the coloring as too high, ok range, or too low. Trying to discern a pH difference of 0.1 or 0.2 is meaningless for pool care.
If your pH is too high (above 8) then lower it.
If your pH is too low (below 7) then raise it.
Any color in between those two, leave it alone.
Ah, my bad. Every Taylor test I perform results in ppm numbers
except pH, which Taylor calls "pH units." Thanks for the correction.
But I'll need to take exception to the rest of your statement. Advising to leave pH alone unless it goes out of the range of 7-8 is an oversimplification of pH management. There are many reasons to adjust your pH to a more restricted range. Personally, I don't want my pH to stray beyond two "pH units" of my target, and I generally maintain my pH even closer to target than that. I determine my pH target weekly using Pool Math calculators, which are based on CSI, a rather important consideration for those of us with plaster-based finishes, IMO. I regularly adjust pH to maintain a CSI that is best for my finish. Since CSI is affected by several parameters (salt level, water temperature, CH level, etc), which change seasonally and for other reasons, my pH target changes throughout the year, and any time I adjust CH. This level of pH management is a personal choice, of course, as some would argue it's not entirely necessary. But I prefer to keep my CSI (and so pH) in check, to help maintain my finish's appearance and hopefully its longevity.
Read up on CSI here at TFP and how it can affect your finish, and make up your own mind about how accurately you want to maintain pH. Keep in mind that where you live, and the type of fill water you have, can be part of the equation.
Having replaced my finish because of the previous owner's careless maintenance of pH and CSI, I know first hand how a finish reacts to improper pH/CSI management vs proper pH/CSI management, so, for me, strict pH level maintenance is what I choose.
For some pools, a pH reading between 7-8 is just fine. For other pools, I believe it's possible to increase your finish's lifespan and maintain its appearance as much as possible by monitoring and adjusting pH more accurately. TFP can help you determine which is best for your particular pool, if you're interested.
