Does anyone have a good aftermarket equivalent for Pentair 263042Z?
Alexr54
193
Florida
These pentair flappers cost like almost $50 each now.
I need 4 of them every 6 months or so to keep up with maintenance.
Im sorry but that price is ridiculous for what it is.
I saw plenty of similar aftermarket for 1/4 the price.
But was hoping someone here may have a recommendation before i try it.
I dont have it on hand. But soon as i can find it i will share.
I am sure i read it somewhere.
To be clear tho. Just because it recommends 6 months. I don't replace them every 6 months. Sometimes i can go years.
I probably should replace them more often tho. Mainly on my caretaker99 which takes 2 of them.
Once a flap broke off and i had to fish it out half way in the piping. Was not fun!
The other 2 i have are at the outlet of the spa filter and pool filter.
Regardless. Would be great if anyone can recommend a cheaper replacement.
Thanks!
Post pics of your equipment pad from a few different angles showing the locations of the 4 check valves.
While a flapper coming loose or breaking every so often isn't unheard of, needing to replace them every 6 months shouldn't be remotely necessary.
Post up the documentation supporting this replacement interval when you find it.
Sorry for bad pics. And its kind of a mess right now. Also only chance i had was when its already dark out.
If i remember correctly the 6 month interval is in the Zodiak Caretaker99 8-port maintenance instructions, in the original manual.
Which i doubt i will be able to find.
I really do plan on replumbing the equipment. Looks like a maze to me. And some parts are overkill i think.
I did this a long time ago with my father when he was still around. Since then its sprung some drips. And i would really just like to tighten it up and simplify it if i can.
Pump on the left (closest to heater) is the spa pump. The other is the pool pump.
I'm also adding in a auto top off. But trying to figure out where is the best place to put the hose that will fill in the top off water.
