Hi TFPers,
In a heat wave here in the Tri-Valley of Northern California. I have been using a solar blanket for about 3 seasons now. Really helps to retain heat, reduce evaporation, and reduce chlorine burn-off. My sweet spot for our water is anywhere from 84/85-90. My 4 year old twins will stay in forever at these temps. Anyhow, with the air temps in the 90s-100s right now in the daytime, and 70s-hi 60s at night, I have been leaving my solar blanket off during the day/night. My solar heating is not even being used too much because, using just this AM as an example, the water temp was 84 in the AM and now it is 87. My solar heating set point is about 85ish.
This has been costing me some more chlorine usage as I have been adding about 30-40 oz per night of my 12.5% chlorine. But, that is to be expected with warmer water and air temps. My CYA is 30, FC goal is 4-6, and my CC 0. With no cover and pool usage, I could have FC burn-off of 2-3 ppm. So, even when I have a FC of 6 at night, I still add some chlorine just to be safe.
Anyhow, what are your parameters as far as leaving your solar blanket off? Do you put it back on regardless? Curious what other TFPers do who use a solar blanket and have hot summers.
