Hello all,
We are new to this whole pool business... We bought a home with an inground vinyl liner pool, 21,500k gallons. It has been nothing but problems. We have replaced the plumbing, the sand in the filter, the multi port valve and are now wondering if we need a new pump motor. Here's what happened today: I checked the return jets to see how well water was pushing through them. One of them was great and one was very weak. My husband checked the pump motor and it was burning hot to the touch. Our valve typically runs at 32 psi. When you start up the filter, it takes a few minutes to get there. It's like it's trying to work up it's courage. Then, it'll run fine and both jets will have great water pressure coming through them. After a little while, one of them will have weakened pressure and the pump motor will be hot. Is 32 psi normal? The filter states a max of 50 psi. The pump motor is a 1.5 hp hayward super pump.![20170527_110729.jpg 20170527_110729.jpg](https://www.troublefreepool.com/data/attachments/51/51023-7bb5fa08c2528279eb5862f0812e9a1c.jpg)
