Had to drain and re-fill pool so I'm starting from scratch on the salt. Looking to get to ~3500. Tested with my K-1766 test kit (which I've had for a few years now) and confirmed a 0 reading before adding any salt.
PoolMath said I'd need to add about 380lb for my 13k gallon pool. I added 240lb to start, which only raised the level to 600. Added another 160lb (for 400lb total), which only raised the level to 1600. My SWG (a Circupool SJ-35) doesn't give a numerical reading, but has a salt light that turns on if salt level is too low. That light is on.
Water temp is about 65.
Probably should have thought about the possibility of bad test regents before, but between the low results and the light on the SWG, I figured it was still low and I added another 160lb of salt last night. SWG light is still on and new test this morning only shows 2200. That's 560lb of salt, which should be way too much.
Wondering if I overdid it due to bad results from my K-1766 kit. Do these regents go bad? It's been stored indoors on a shelf, so not exposed to extreme temperatures or anything.
