Howdy,
I just purchased my first solar cover ever, for my 11' x 60' lap pool, and could use some advice from experienced cover users. I actually purchased a 30' x 60' cover, the Clear 2400 Series 12mil thick cover from Doheny's, so I will be cutting it to get two full-length covers out of it plus pieces to cover my attached spa, stairs and swimout bench.
My question is: should I cut the cover larger than the pool dimensions (11' x 60') to account for shrinkage over say the first six weeks of life on the pool? I'm getting mixed opinions. I just spoke to Doheny's and they say shrinkage with their solar covers should not be an issue, that shrinkage is only an issue with vinyl liners. But the web site for the cover reel I purchased (Rocky's Reels #5A) states to allow a 1.5 inch wide border around the pool edge to compensate for shrinkage, in other words cut the cover 3 inches wider and 3 inches longer than the pool dimensions. I've read other sources that also say to allow for shrinkage, then go back 6 weeks later and do a final trim.
What say you? Have you ever experienced a pool solar cover shrinking by any significant amount? If you trim your covers, what do you do? I think I'm going to take it to my local park/soccer field to do the trimming! Thanks!
