Hello! I'm very excited to join this community. I could really use your advice!
I'm a relatively new pool owner (this summer is my second full season). I live in CT and have an in-ground pool. 20x40, about 24K gallons. Chlorine, not salt. Using FiberClear in my filter. I shock with HTH advanced cal-hypo (2 bags a week) and I have 4 tablets of bioguard silk in the floater plus one in the skimmer.
My pool is crystal clear, however, whenever I shock the pool and run the filter once a week at night, I wake up to find clumps of yellowish "dust" at the bottom of the pool. These clumps are mostly concentrated at the deep end, though smaller piles can be found in other areas of the pool. I've been vacuuming these piles to waste.
On Monday June 17th (after having added 2 bags of shock on Saturday night), I went to the local pool store and told them what was happening. We did a water test and here are the results:
Free Chlorine 0.09
Total Chlorine 0.15
Combined Chlorine 0.06
pH 7.6
Alkalinity 73
Adjusted Alkalinity 76
Hardness 207
Cyanuric Acid 8
Iron 0.10
Copper 0
Phosphate 0
The store recommended I add a Phosphate reducer (just in case, even though the levels were 0) and Pool Enzyme, then take out the filter and clean it, vacuum pool to waste, then add 4 bags of shock. I had been reading this forum before going to the store and knew I shouldn't have bought anything, but I caved, spent the $50 dollars and followed the steps. I added the Phosphate reducer and Enzyme monday evening, cleaned filter/vacuumed and topped up water wednesday afternoon, shocked Wednesday evening, and then on Thursday vacuumed to waste the dust that formed again after shocking and topped up the water again. I went to the pool store today (friday). Here are the results
Free Chlorine 0.28
Total Chlorine 0.34
pH 7.4
Alkalinity 76
Adjusted Alkalinity 73
Hardness 246
Cyanuric Acid 13
Iron 0.3
Copper 0.2
Phosphate 0
While my chlorine levels are up a bit, they are still low. The store suggested I buy zip chlor and add it tonight, but I declined because I wanted to get this group's advice first.
To reiterate, the water is still crystal clear. The only concern I have is why there seems to be dead algae after every shock treatment and why I can't get my chlorine levels to the normal range despite shocking and using expensive floater tablets. I realize now that my frequent vacuuming to waste and topping up the pool (~500 gallons a day twice this week), might also sending out some of the chemicals I added and contributing to the problem... I should probably be vacuuming the dust to filter and then backwashing.
Should I go the zip chlor route or do you think SLAM is appropriate for my situation? Ready to buy the TF Pro if you think I need to SLAM.
Thank you!!
Free Chlorine 0.09
Total Chlorine 0.15
pH 7.6
Alkalinity 73
Hardness 207
Cyanuric Acid 8
Iron 0.10
Copper 0
Phosphate 0
Free Chlorine 0.28
Total Chlorine 0.34
pH 7.4
Alkalinity 76
Hardness 246
Cyanuric Acid 13
Iron 0.3
Copper 0.2
Phosphate 0
Thank you!!
