He went full pool store. Never go full pool storeHaha. Exactly....
That is an incredibly large FC loss in hours of darkness. Can you try to post a couple pics of your pool please? Wide shots so we can see it from a couple angles?Another day another 7ppm of FC lost overnight.
That is a crystal clear, gorgeous pool. In one pic did I see the small 3 inch LED lights? No large light correct?
Also, how old is your pool? Has anyone ever removed the drain cover to clean or inspect?
I'm trying to test every 2 hours and I do have to add LC mostly after each test. How soon should I be testing after I add more LC? The Chlorine appears to be new from Walmart. Not even dust on those 1gal bottles unlike from Lowes that I had before. I'm on my 9th gal.Also, Just to rule it out…. You are verifying you hit your target after adding, correct ? I doubt the new bleach is bad, and would have suspected the old bleach as a possibility, but still. It’s a possibility.
Or your gallons is off.
Or pool math is set to the wrong gallons because you helped somebody else and forgot to configure it back to yours ? Ask me how I know.
With water that clear, I’m thinking it’s a testing / adding goof.
30 mins after adding. Just once to verify you reached your target as that is now suspect.How soon should I be testing after I add more LC?
Is poolmath configured for 11k still ? If not it’s telling you the wrong amounts.My pool is just under 11k gal according to the engineering plan
The app is still configured for 11K. I cleaned the filter about a week ago and didn't see anything unusual. I'm trying to clean it every month. Just in case I will clean it again now.30 mins after adding. Just once to verify you reached your target as that is now suspect.
If everything above is good the only thing I could guess left is the filters. If they are harboring old algae that you’ve now cleared from the water you could be adding it back, which promptly gets eaten by the pool but you see the loss.
Perfect!Just in case this is the Chlorine I'm using and this is what I have in the app. Looks correct?
Ok great !!The app is still configured for 11K
Ok great again. If you cleaned it last week it probably is fine. Open it and see regardless just in case, but it’s probably not it with the new info.I cleaned the filter about a week ago and didn't see anything unusual. I'm trying to clean it every month. Just in case I will clean it again now.
Right again.Just in case this is the Chlorine I'm using and this is what I have in the app. Looks correct?
Filter that I just remove.Perfect!
Looks as I would expect. No problem there.Filter that I just remove.
You're doing a great job and have been super vigilant.Super clean now
