- New pool owner (year 2)
- Last summer the light worked as expected.
- One day it no longer worked, and I "assumed" a bulb will fix the problem?
- Today, I took out the fixture (see below for pic), and while googling MR16, i found this site MR16 Light Bulb which had the same numbers that were on my bulb and they suggested a $23 bulb
- Will this bulb work? If not suggestions?
- Is it really this simple? Do I just take out the existing bulb, and replace with new bulb? (and also replace gasket)?
- Are there better alternatives? The existing (burned out light) did change colors which is of course fun, so are their better alternatives (without changing the fixture) or is a quick $23 fix the way to go?
- Suggestions are welcome.
Some numbers on my bulb:
- "165WATTS, 120V Bulb Type MR16, 75W"
- "series 600015, 600016, 600017 and 600022"
Here's a pic if it helps
