- Jun 21, 2019
- 124
- Vinyl
- Intex Krystal Clear
Hello I know this might be a silly question but do I need to add pool salt to a pool yearly? I opened my saltwater pool today and got it cleaned, ran the pump for 30 minutes then tested my water. Below is what I got...
FC - 1.2ppm
CC - .8ppm
Ph - 7.0 (7.43 digital)
TA - 90 maybe 80 ppm
CYA less than 30ppm
Salt - 1698-1717ppm
I then entered this into pool math and added 2 lbs of CYA and the dosage amount of bleach aka chlorine to reach slam level. The pump filter is running for a 24 hr cycle with thr vacuum. My question is do I still need to add pool salt or do I just keep adding chlorine to get to slam level?
FC - 1.2ppm
CC - .8ppm
CYA less than 30ppm
Salt - 1698-1717ppm
