Hello TFP Friends,
I am almost ready to start up my pool for the first time and am trying to ensure the equipment is setup properly and meets city inspection requirements. My question is concerning the city requirement that "the pump and heater must be on a timer with a fireman's switch." I am not sure if this is needed because I'm am under the impression that my automation panel (Pentair Intelliconnect) will function as a timer and the heater (Raypak Avia - gas) has a water pressure switch that turns it off if water is not provided. For this reason, I decided not to install the timer + fireman's switch. My understanding of these components could be off-base because this is my first pool and I am still learning.
My questions...
1. Does the Intelliconnect + heater's built-in switch take care of preventing the heater from running without water OR do I actually need to install a timer + fireman's switch to prevent damage? My thoughts was to explain the built-in functionality to inspector when asked about the timer etc.
2. If my current setup (no timer or FS) is fine, should I be okay relying on that? Should I go ahead and have a timer + FS installed to avoid future issues?
My pump and heater is currently wired into Relay 2 on my Intelliconnect.
If anyone has similar equipment, how did you set yours up? I also have an Circupool CR-J swg, is it necessary to have it on a timer switch too. I was planning to program it to work in accordance with the pump's scheduling. I have seen others install a separate timer for swg but not sure if that's necessary. I've read a lot of other posts but all they do is confuse me more. Thanks in advance for your input/recommendations.
My questions...
