Do I need a T-15 cell?
aztony
229
Maricopa, Arizona
Hayward Aqua Rite (T-15)
Hi, my puppy chewed the cord to pieces on the Hayward Salt Cell. I have a 15,000-gallon pool. The cell I have is a T-15. I'm assuming the cord cannot be replaced and I need to order a neq salt cell. I see that the T-15 is for a 40k gallon pool. Just wondering would a T-3 or T-9 work. Is the T-15 overkill? TIA
We recommend you get an oversized cell. With a T-15 you can generate the CL you need while running your pump 6 hours or less. With a smaller cell you will need longer pump run times to generate the same amount of CL.
A larger cell should last longer as long as your puppy does not chew the cord again.
Thanks for the reply. The pump runs for 8 hours, from 9 PM to 5 AM.
With a pump run of 8 hours a T-3 could not generate enough CL running at 100%; a T-9 would barely do it running at 100%; you would likely run the T-15 at around 40-50% for 8 hours.
I've been pricing a new T-15 and saw some generic ones pop up. Just wondering if anyone has bought them or has experience with them. Are they any better or worse?
There's presently someone selling a T-15 on Ebay for parts only for short money. It may be possible to swap the cord with connector at the cell. I'm not familiar with the cell but the photo shows a small plastic cover where the cord is attached and it's possible that cap may simply snap-off and the connections could be remade. Worst-case the middle of the cord could be pieced-in if both ends of your cord are intact. Something to think about considering the cost of a full replacement. If the multiple wires are color coded then reattachment might be straight forward. Then again, if your cell is old and near end-of-life then maybe it's best to simply replace it.
Update: I ordered a new T-15 off of Amazon. Took a couple of weeks to get here from CA. Issues with delivery. Anyway, installed it a little over a week ago along with new o-rings. I've been having a problem getting the water chems balanced. The water temp keeps reading Cold, except for yesterday. When I do the pH test the color is yellow, salt is at 3000. They're the only two tests I've done. The salt was reading low at the beginning, I'm asuming because there was no SWG for a few weeks and having some rain. Actually, I used an old SWG that I had replaced just to have the water circulate every day. Wondering should I do the other tests or work on the pH first? Do I need to shock the pool? The water looks good. Water temp is reading 50F, that's why the reading says cold.
You need a proper test kit for your water chemistry levels.
Order a TF100 test kit
The only other real option for a test kit is a Taylor K-2006-C. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. You need to get the K-2006-C to get the larger bottles that you want.
I also have the SpeedStir. It makes testing much easier.
For salinity the best is a Taylor K1766. There are strips that are OK. Right now with cold water, I would turn off the SWCG and use liquid chlorine to maintain your FC based on the FC/CYA chart in Pool School.
Reactions: aztony
SWG will not operate when water that cold. Use liquid chlorine and treat your pool as a non-swg pool until the water warms up.
We do not “shock” pools. If you suspect you picked up algea then do a Overnight Chlorine Loss Test. If you fail the Overnight Chlorine Loss Test or have CCs 1 or above then you need to follow the SLAM Process process.
Do a complete set of tests with your TF-100 and post the results.
Reactions: aztony
Do I let the pump run and turn the SWG off until the water warms up? Is it okay to do all the tests with the water cold?
Yes, run the pump and turn off the SWG. Maintain your FC level with liquid chlorine.
Yes. CYA test water should be taken inside and let rise to room temperature.
Reactions: aztony
You only need to run your pump during cold water times enough to skim the surface and mix any chemicals (liquid chlorine and/or acid). I only run mine a couple hours a day when the water temperature is below 60F. Once it reaches 60F, I turn on the SWCG and run the pump enough to generate the chlorine I need.
Reactions: aztony
Test:
CH -450
TA - 10
CYA - 50
pH - -6.8
Salt - 3000
FC - 0 (remained clear)
Add chlorine to get your FC to 6-8ppm ASAP.
Raise your pH & TA with soda ash. Use PoolMath to calculate dosages.
From Recommended Pool Chemicals
Soda ash is available as ARM & HAMMER® Super Washing Soda Detergent Booster. Do not confuse this with ARM & HAMMER® laundry detergent! It is sold in the laundry detergent section of most larger grocery stores and some big box stores. It is also sold by pool stores under various names, including PH Increaser, PH Up, Balance Pak 200, etc. Soda ash is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
Reactions: aztony
Just to be sure I have the correct chems. I have Borax detergent booster and chlorinating liquid. Are those what I need?
Borax raises the PH and also raises the TA level just a little. If your TA level is low soda ash will raise both the PH and TA levels.
You need to raise both pH and TA so soda ash is preferred.
I don’t know if Borax chlorinating liquid has no additives. You have to read the label or post pics.
