Stop worrying. It's doing what it's designed to do. It disables the heater when jets are on high to reduce the amp draw so you don't trip your breaker. SOP for most spas. You can change it on most, but would need the higher rated wire and breaker for it to work.
"Polling" stops "cycling", where your pump and heater turn on for 30 seconds every 5 minutes. Very hard on equipment, especially circuit board relays.
I know! ("stop worrying")
What bothers me the most is when I bought a top of the line stereo it had the schematic on the back page, my televisions had a schematic in the back, and even the cars had manuals you could purchase reasonably priced. We spent 12,000 and the only schematic is a block diagram buried inside it.
I had called Balboa requesting a service manual and they treated me like I had two heads! It's always been difficult to impossible to obtain stuff like the programming for the board's eeprom but this world's just gone bozowacky.
So there, I said it. I reckon I'm always the guy who wants to "do more than the universe wants me to".
On amps, I'd have to pull the tables back up, but I did run wiring myself --- went on the cheap and just put what they recommended despite seeing a warning on youtube where one guy always ran 4 AWG, but I ran 6 AWG because I'm a cheapskate and my neighbor's work had tossed a spool of it about a decade ago. So it's 6 AWG and a 50A breaker, plus 50A disconnect/GFCI outside with the tub.
So anyway I agree with you, 10A on high with the main pump, 4 kw heater (4000/220 = 18.2A), and if (IF) the board allowed the aux pump another 10 A = 38A. 80% derating on 50 = 40A, very close but timed to a 15 minute cycle seems smack in the grey area. But, if I'm in there dead of winter (not likely) and the water temp is dropping, well, given a proper service manual I'd seriously consider rigging the darn thing for two "extra" modes, 1) heat with the main pump and aux drops the heater relay, or 2) forced polling mode. Alas, no service manual, no programming info. Pity is for decades you can buy a drop-in eeprom for your car, but not you hot tub.
Yeah you are 1000% right, I worry too much. Maybe I've lived too long but I remember when, well, I'm not going there.
I will say this though, because I'm handy (programming, electronics, electrical, plumbing, small/large appliances, cars, small engine, carpentry, HVAC), I'll be right back in the thick of things the minute a new situation comes up, like *dosing when I'm on vacation or eventual repairs when the circuit board relays get tired of doing their thing.
@RDspaguy, I've been reading through this entire forum sub-group, hot tubs, and very much appreciate what you do here. I've seen you take some flack from other so-called experts on occasion and it seems (very) undeserved. Thank you for your reply, and thank you for being here. You are an absolute treasure.
Methuselah
* was looking at
this.
