Do I have a bum regent?
geempool
43
Buffalo NY
CircuPool RJ-60 Plus
I've been away for a week. Before I left, I started with a fresh batch of all new TF-100 refill regents. The day I left, I bumped the chlorine up to the highest swimmable level (9). Water was crystal clear, and swimmers reported everything was great while I was gone.
No one has been swimming or looking at the pool for the last two days. The pump was left off.
Now I am back. There are some leaves, the water is still clear, doesn't smell bad. I backwashed and turned on the filter.
I came back an hour later to test the water.
Doing the chlorine drop test, I got zero free chlorine or combined chlorine. Same on the chlorine box test. Not good.
So, I added 2 gallons of bleach according to the pool math suggestion, aiming for 7 chlorine.
Now, about 2 hours later, I still get barely 2 free chlorine, and .5 combined chlorine doing the drop test, but the box chlorine test seems to be reading much higher than 2 chlorine -- more like 5-10.
Should I add another jug and a half as suggested by the drop test, or is the chlorine likely actually higher as suggested by the box test?
Do I just need to wait longer to accurately drop test?
Are my drop chlorine regents malfunctioning? Or the box regents?
Thanks for any suggestions!
You should do an overnight chlorine loss test. If your pool’s FC was at zero for more than a few hours, algae can easily start to take hold. A pool can be clear in the early stages of an algae bloom. It doesn’t necessarily turn the water green or leave mats of green growth right away.
