If you can't even tell the difference between 120 and 240 breakers, then no you should not be doing this. I don't care if you have done it before, if you have to ask that question then you shouldn't be doing it.
Using the wrong breakers can cause a fire in your panel. If you have to ask a pool forum which breakers to use, you are NOT QUALIFIED to do the job.
