I get a lot of mice around my equipment pad so definitely want to keep them out. I've already seen the recommendations for the MK Rat Proofing stuff. As far as I can tell, it's just chicken wire and self tapping screws, which I already have. So I figure why not DIY it. I just want to be sure not to block anything important related to air flow or otherwise.
Fwiw, the new heater is the Pentair MasterTemp 400.
I was planning to just cut 1/4 in chicken wire and attach directly through the housing with self tapping screws. Based on the videos I've seen, it looks like there's no issue with doing that over the side vents. But I'm unsure if it's ok to do so in these other spots?
- Where the gas line goes in. I would think this would be safe to block with the chicken wire?
- Exhaust. Obviously I don't want/need to block the vent itself, but how about the gap around where the flue meets the heater body?
- Underneath the unit. Do I need to bother blocking mice from getting under the heater? Not sure if there's any access point from underneath into the unit. Also not sure if the heater has air flow underneath for a reason that I shouldn't mess with.
Thanks so much!
Thanks so much!
