I got the ground pretty level now. I did end up cutting the high spots and using that dirt to fill the low spots. Had several inches of rain last week that really helped settle things. Drove over it many time with the big tractor for good measure.
Before doing the final leveling, I decided to get started on the walls. Here's the first pine after cutting it.
Cut to exactly 40' and ready to be placed. My co-pilot is making sure I get the placement right.
Another angle.
Here my helper is using the tamper bar to get the log just right.
Side view.
Tractor / mountain view just for kicks.
Second log ready to be set.
Second log in place.
So my plan now is to back fill with all the rocks I pulled out during excavation and then build up the 2 side walls with 2 logs as well and back fill there as well. Next I plan to set posts to hold the logs in place, and then add a 3rd log all around and back fill back up to level and so on until I'm done. I'll add some bracing as well.
Another angle.
Side view.
