So I’ve been fighting to get my pool opened this season, and while I have it at a teal blue color, it’s still cloudy and I cannot see the deep end.
Chemistry is still a bit off as I only got my Taylor kit yesterday, and I was using pool store’s testing results to adjust the water (I know, I know..). If my first FC test was correct, I’m around 42.5 with 0 CC, with CYA at 55.
Anyway, I was noticing some dirt coming back out from when I was vacuuming using filter mode, and I finally disassembled the multiport valve.
This was its state before cleaning, so it totally makes sense that I’m getting crud back into the pool:
I’ve cleaned up as best I can:
So it looks like I definitely need a new spider gasket. Has anyone just replaced the gasket on the diverter itself (Pentair 272512), or I am assuming that it’s probably just easier to replace the whole part since the gasket is glued in.
Now the question I have is, there are some scuffs and abrasions on the bottom part of the MPV, along the outer circle.
Will a new diverter and gasket be enough, or do I really need to replace the entire MPV? When replacing the diverter, do I lube the spider gasket (one video specifically said not to)? Also, does it matter if there is some sand/dirt in the bottom sections?
