Hi all,
I'm not sure if there's other folks that have this problem, but I really have a hard time telling the difference between the pH 7.8 and pH 8.0 colors on my test kit and my pool loves
to run up in this range. Current numbers are: FC 5.0, pH 7.8 or 8.0, TA 70, CH 380, CYA 40, NaCl 3400. I have found that, for my situation, it appears that if I add a drop of R-0005 the
color drops by 0.2 pretty reproducibly for my pool. I can read all the other colors fine and I was wondering if you think I can use this to tell the difference between pH 7.8 and pH 8.0.
If I add a drop of the R-0005 and it turns to the pH 7.6 color, then I know it's 7.8, if it stays that color that's hard to read, then it's at least pH 8.0, maybe more. Does anyone see a problem
with this? I've tested it a few times and it seems to work okay for a range of pH readings. I'm curious to hear your thoughts. Thanks, Tony
