I just setup my 16x48 intex pool and after I had about 4 inches of water in it I discovered water leaking out from under the pool in several places. I don't see any leaks on the sides so it has to be some where on the bottom of the pool. What is the best way to find out where the hole(s) is? Should I just drain the 4 inches of water out and try to find it? Or can I try looking with the water still in it? Visually I can't see where its leaking.
Thanks, Todd.
Thanks, Todd.
